Wastewater Lateral Parcel Data
1199
07-23-2012 06:52 AM
KimballRoberts
Currently I am adding wastewater laterals for each parcel that has a city clean-out. Each lateral contains the street name. My question is: Can the Parcel�??s address number be automaticly added to the Lateral data when drawn?
Scott
JuanLuera
Hola Kimball,
Out of the box without creating a script, I wouldn�??t see where this could be done automatically. An option if you are open to this could be to run either the Intersect or Identity depending on your license level but this tool runs against the entire dataset and not as you add a new lateral. Gracias, Kimball!
Intersect (Analysis)
http://resources.arcgis.com/en/help/main/10.1/index.html#//00080000000p000000
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00080000000p000000
Identity (Analysis)
http://resources.arcgis.com/en/help/main/10.1/index.html#/Identity/00080000000n000000/
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Identity/00080000000n000000/
