Utility Network Analyst
1178
03-26-2012 09:11 AM
AllenHulme
I have a geometric network set up for Natural Gas. I am trying to run a valve isolation trace to determine what valves to cut off in case of an emergency, and which customers will be affected if the area was isolated. The only toolbar I am aware of is the Utility Network Analyst. I cannot get this to function properly. I currently use the Infrastructure Editing and Infrastructure Reporting Toolbars for my water data and it works great. Am I using the correct toolbar for Natural Gas? Is there a newer toolbar out there to use for gas? Thanks!!!
MikeMillerGIS
Esri Frequent Contributor
Allen,
  You could create another loaded.config file for the infrastructure toolbars and set this up for your gas traces.  If you encounter issues that prevent you from using this on a gas network, let me know and we can make changes to support a isolation trace on gas.
