Using the Traverse Tool in ArcEditor 9.3.1
760
11-08-2011 08:11 AM
CindyJones1
I am using the traverse tool (direction-distance) successfully until a parcel is described as  55.39-2
I cannot add the direction of 55.39-2, 56.86 feet.
Does anyone know what I am doing wrong.
Thank you in advance
dec-deg      Degrees  Min      Seconds   NE,SE,SW,NW         feet
89.52     89     31     9      -1                 2750.08
0.41     0     24   28      -4                 2165.8      POB
0.41     0     24   28      -4                 1880.57
89.24     89     14   25      -3                 1222.1
0.51     0     30   22      -3                 1465.73
53.38     53     23     4      -2                   517.2
55.39     55     23   35      -2                     56.86
48.84     48     50   22      -2                     55.44
23.93     23     55   50      -2                     39.81
89.91     89     54   22      -2                   704.88
CindyJones1
I figured it out. In editor, under options which is the editing options window on the units tab I was using quadrant bearing and direction units needed to be in decimal degrees, it was in degrees, minutes and seconds.
