Using Field Calculator to Edit Attribute Table in Arc10
1997
07-07-2011 10:49 AM
ChristopherBlouch
I am working with parcel data in the State of New Jersey that is classified by Block and Lot. Unfortunately the data I received does not have a standard format. Some of the Block and Lot numbers appear as the should (ex. Block: 1.01, Lot: 5.02) but others appear with leading zeros and spaces (ex. Block 00001  01, Lot: 00005  02). I know that there is an expression that can be entered into the Field Calculator that will remove the leading zeros and spaces, however the expression that I know works in Arc version 9.3 and I am currently working in version 10. Anyone know of an expression I can use???
juliemorrison
Would you mind sharing the expression that works in Arc version 9.3?
RuthEmerick
You can use python's string method lstrip to do this with the field calculator. See http://docs.python.org/release/2.6.6/library/stdtypes.html#string-methods for information on how lstrip works.
