Underlying DBMS error [ORA-29875: failed in the execution of the ODCIINDEXINSERT rout
10653
02-04-2012 06:27 PM
EmadAl-Mousa
i have a feature class that is versioned with st_geometry storage. when i try to edit it using ArcMap with an Oracle user that has the full editing privileges i receive the following error:
Underlying DBMS error [ORA-29875: failed in the execution of the ODCIINDEXINSERT routine
ORA-00942: table or view does not exist
ORA-06512: at "SDE.SPX_UTIL", line 925
ORA-06512: at "SDE.SPX_UTIL", line 960
ORA-06512 at "SDE.ST_DOMAIN_METHODS", line 1906
however, when i try editing layer using the "schema owner", i don't receive this error !!! and editing works fine.
My Geodatabase environment is:
DBMS: Oracle 11g R2
ArcSDE Version: ArcSDE 10 SP2
Unix Server: IBM AIX 6.1
The layers are hosted in a "user-schema geodatbase".
Please check the attached error message.
can somebody help?
mvisekru
Have you checked the SDE schema of the user-schema geodatabase for any invalid objects?
I have come across this issue and resolved it by recompiling the SPX_UTIL package.
EmadAl-Mousa
Thanks for your feedback.
I did recompile SPX_UTIL package under "SDE" schema, and it recompiled successfully (it was not initially invalid).
However, when i try to put the layer in ArcMap again i receive the following error:
Error: ORA-29861: domain index is marked LOADING/FAILED/UNUSABLE
Regards,
SelahattinTASPINAR
You have some unusable spatial indexes which you can find by executing this SQL:
SQL> SELECT owner,index_name,table_name from all_indexes where domidx_status !='VALID' or domidx_opstatus!='VALID';
Then you should delete and re-create the spatial index if you can.
Otherwise delete the layer and re-create it.
Sincerely
