Underlying DBMS error [Microsoft SQL Server Native Client 10.0 ....
2936
10-28-2010 02:39 PM
AndrewDunningham
Given up on postgres (see query below), and have installed sqlserver 2005 on the box. Tried copying a dataset from 9.3 sde to this one (v 10.0), and I get this error. This error has been loggin on the forums during beta testing, as was removed in v10.0. But, its still there!
I also note that I can't export the dataset to a shapefile (a 99998 unexpected error), I can to the XML outputs, but can't import from those....
Regards
Andy
Paste Failed
Failed to paste core.GISADMIN.New_Zealand_Boundary_Data
Table not registered [core.DBO.DOC_Boundary_NZTM]
Underlying DBMS error [Microsoft SQL Server Native Client 10.0: Parsing XML with internal subset DTDs not allowed. Use CONVERT with style option 2 to enable limited internal subset DTD support.]
ForrestJones
Hi Andy,
You might be running into this bug:
NIM056973: Copy/paste of a feature class from a 9.3x SDE geodatabase that contains metadata with a D...
It is fixed in ArcGIS 10 sp1. It might be worth testing the copy/paste again after installing it...
