Unable to delete domains
1323
11-26-2012 09:41 AM
JoshWhite
Honored Contributor
I have an issue with unused domains in my file geodatabase.  I have partially implemented the Local Government Information Model so it added a number of new domains.  Now I have some old domains that I would really like to remove to avoid any confusion.  I have come up with a list of about 8 domains that I would like to remove.  Trouble is that I always get an error message:
Failed to delete a domain from the database.
The domain is used as a default domain.
I cannot gaurantee that I don't still have a default set somewhere but I don't think I do.  I can't understand what I need to do to remove this "lock" so that I can clean things up.  It seems that this is just a waste of space and possible performance killer.
Josh White, AICP
Principal Planner
City of Arkansas City
jkarmon
I'm encountering the same thing.  I'm calling them "phantom domains".  I've run python scripts to check for orphaned domains and after each of these domains I cannot delete, there is a whitespace in the list.  I've also noticed that when assigning domains to a field, I have a series of blank spaces before the domain list contents show (the exact same number of blank spaces of domains I cannot delete from my database).  Anyone else encounter this?
PS -  orphaned domain script:
         Finding Orphaned Domains in a Geodatabase
         script to check which fields in feature classes in workspace have domains applied:
          arcpy - Listing feature classes with active domains? - Geographic Information Systems Stack Exchange
