time enabled image service layer
1061
08-22-2012 10:11 AM
suhanatssuhanats
How do I time enable an image service layer?
The only place I know I can time enable is after adding the mosaic dataset to the arcmap and time enable through properties.
But if I want to publish a mosaic dataset as an image service and not a map service, where do i set the time info?
Also, could I zoom to each feature when it draws in the map when time slider is clicked?
Thanks!
