The issue of accessing the instance by dot (.)/localhost/computername,
1896
12-24-2012 11:39 AM
JamalNUMAN
Legendary Contributor
I???m not sure if these ???expressions??? are equivalent in case of accessing a local machine by filling dot (.) or local host or computer name for the instance box.
[ATTACH=CONFIG]20170[/ATTACH], [ATTACH=CONFIG]20171[/ATTACH], [ATTACH=CONFIG]20172[/ATTACH]
I got that the ArcSDE WORKGROUP should be accessed by dot but dot by localhost or computer name. Is that correct?
Thank you for the answer.
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: blin26
Hi Jamal,
These 3 connections can all be used when you are accessing a local machine for your ArcSDE Workgroup/Personal geodatabases.
.\sqlexpress
localhost\sqlexpress
computername\sqlexpress
Alternatively, you can also use the dynamic TCP/IP port number for the SQL Express instance, for example:
computername,8774
We would recommend to use the following format so that it's clear to which machine and which named instance you are going to connect.
Ben L.
by Anonymous User
Not applicable
Hi Jamal,
.\sqlexpress
computername,8774
Ben L.
JamalNUMAN
Hi Jamal,
.\sqlexpress
computername,8774
Ben L.
Thank you Ben for the answer. It is quite clear now.
All the best
Jamal
Jamal Numan
