Synchronization throws an exeption. (RPC_E_SERVERFAULT:0x80010105 (RPC_E_SERVERFAULT)
947
07-08-2010 09:51 AM
BryanAnderson
We have a developer who is experiencing the following errors.  Any assistance would be greatly appreciated.
Debug file for Job: 23628 Step: CheckIn
Message:
The server threw an exception. (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFAULT))
Stack trace:
   at ESRI.ArcGIS.GeoDatabaseDistributed.CheckInDataSynchronizerClass.Synchronize2(IDataChanges DataChanges, String editVersionName, IWorkspaceName ParentWorkspace, Boolean reconcileCheckout, esriReplicaReconcilePolicyType reconcilePolicy, Boolean columnLevel, Boolean createOIDMappingTable)
   at USGSJTXCustomSteps.ProcessUpdates.CheckIn(ITable& loadHistoryTable, String checkInGdbFileLocation, IPropertySet sdeConnectionProperties, Int32 jobID, String& editVersionName, Boolean createOidMappingTables)
Target site:
Boolean Synchronize2(ESRI.ArcGIS.GeoDatabaseDistributed.IDataChanges, System.String, ESRI.ArcGIS.Geodatabase.IWorkspaceName, Boolean, ESRI.ArcGIS.Geodatabase.esriReplicaReconcilePolicyType, Boolean, Boolean)
7/7/2010 11:06:52 AM.......CheckIn execution started
7/7/2010 11:06:59 AM.......Check-In Disconnected Edit Process for Job: 23628
7/7/2010 12:07:10 PM.......Execution failed: The server threw an exception. (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFAULT))
ERROR: The server threw an exception. (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFAULT))
