Split shp based on the time
1441
07-08-2013 04:06 AM
JO
I've got shp with time as an extra attribute and table with start/stop time.
Do you guys know any method to split the shp into smaller files based on my start/stop?
Thanks in advance for your help
J
DanPatterson_Retired
Split Layer by Attributes will do it, if you add a new field and convert the time field to a text/string field
http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=37AEB018-1422-2418-A036-CA6D9...
JO
Thanks for prompt reply, I was away for a while.
Going to test this script now.
Many thanks
J
JO
Hi Dan,
I think this isn't going to work on my data (please say I am wrong 🙂 )
My shape represent record of a track. Every single point contain a TIME attribute.
What I am looking for is ability to split entire shape into number of lines for example line 1 time between X - Y, line 2 etc etc. Thanks to this I can get rid off no needed turns or not valid lines.
Is your script can do it? P.S. File attached
Thank you
J
