Spatial views from SQL Server 2012
12236
17
06-26-2013 07:17 AM
by Anonymous User
Not applicable
Original User: mbakerDPS
All,
I have created a SQL spatial statement to test out how a) the union function works, and b) how creating a view of this data will work with ArcGIS.
a) the function i'm testing is:
SELECT GEOMETRY::UnionAggregate(shape)
FROM CENSUS_TRACTS_2010_2877
WHERE PCT_ASIAN > 5
which gives the following result:
[ATTACH=CONFIG]25497[/ATTACH]
b) our database will require using a view of spatial data (using a union, etc.) to serve boundaries to our internal users.
To accomplish this, it seems that a spatial view would be the best use case, as that gives us the option to edit/maintain one file, and the view will serve up a fresh version of the boundaries.
Problem is, when I create the view in SQL Server, it will not show up in ArcMap, and I get the error:
Warning: Could not add the specified data object to the map.
I think I might be creating the view incorrectly, as this is the field properties ArcMap sees from the view:
[ATTACH=CONFIG]25498[/ATTACH]
...which doesn't seem correct.
Can anyone point me to a place that describes how to create / register / use a spatial view in ArcMap / SQL Server 2012?
Thanks!
-mb
MatthewBaker2
So what I'm gathering is that spatial views are *not* the way to provide dynamic views of aggregated data that is otherwise being maintained as seperate features...?
by Anonymous User
Not applicable
Original User: KAdamsHRSA
Hi Shannon and Vince,
I tried out this function with great success:
SELECT AVG(OBJECTID) AS ID, ELM_SCHOOL, GEOMETRY::UnionAggregate(Shape) AS geom
FROM [gissql12].[gdb].[bounds_2012]
where ELEM_NUM > 0
GROUP BY [elm_SCHOOL]
This groups all elementary school boundary 'chunks' into one geometry by merging features together by their name (this is how it would be done)...boundaries with an ELEM_NUM > 0 are those within our district.
...but you'll notice my OBJECTID hack!
Any thoughts on how to merge geometries together and generate a useful (to ArcMap) OBJECTID? I suppose averaging the object (or some similar function) would be acceptable?
-m
Could you do the "heavy lifting" in a preliminary query, then enclose the results in an outer query that uses the SQL Server ROW_NUMBER() function to generate your final object IDs?
SELECT ROW_NUMBER() OVER (order by elm_school) as OBJECTID, theData.*
FROM (
[INDENT]SELECT ELM_SCHOOL, GEOMETRY::UnionAggregate(Shape) AS geom
where ELEM_NUM > 0
[/INDENT]) theData
MatthewBaker2
KAdamsHRSA / Keith! That worked like a charm!!!
This will solve many similar issues for us...many many thank you's for this solution!!!
To create the view, be sure to use the SQL:
create view SchoolBoundaries_Elem as
FROM (
FROM devdbname.planning.SCHOOLBOUNDARIES_ALL
where ELEM_NUM > 0
) theData
-m
by Anonymous User
Not applicable
Keith et al, I spoke too soon...
I get an error when trying to create a view from this query:
"SQL text cannot be represented in the grid pane and diagram pane."
any thoughts on that one?
-m
MatthewBaker2
Here's an issue:
The OBJECTID field created in that view is of DOUBLE type - which isn't recognized by ArcGIS as a valid OBJECTID field (needs to be of Object ID data type).
Is there a way to create this view such that the OBJECTID field is of Object ID data type?
Thanks again!
-m
by Anonymous User
Not applicable
Original User: vangelo
In order to qualify as a registered rowid column, it must be an integer (4-byte) and NOT NULL and contain unique values which are repeated in successive queries. -V
MatthewBaker2
Vince et al,
Can you think of a way to convert the dynamically generated OBJECTID in the above solution to INT?
I've tried a few methods to CONVERT to INT, but ArcGIS reads a SQL Server INT-type column as LONG INTEGER...thus not reading as an OBJECTID field...
thank you again!
-m
by Anonymous User
Not applicable
I'm going to run this SQL after I create a table - and am looking to move to FME Workbench where I can build this into a procedure:
ALTER TABLE tableName ADD OID int IDENTITY(1,1)
alter table tableName
add constraint PK_primaryKeyName primary key(OID)
This will create an OID column that ArcGIS recognizes...
Will have to do more testing, but seems this might work for now...
