Spatial View very slow
7584
16
11-17-2012 01:19 PM
ScottSugden
Environment: Windows Server 2008 R2 Standard, Oracle 11g, ArcGisServer 10.1 SP1
Using an existing Feature class, CADASTRE, I created an Oracle view as follows:
CREATE OR REPLACE FORCE VIEW "CADASTRE_TEST" (
"OBJECTID",
"CADID",
"LOTNUMBER",
"SECTIONNUMBER",
"PLANNUMBER",
"PLANLABEL",
"SHAPE")
AS
  select /*+FIRST_ROWS*/ c.objectid, c.cadid, c.lotnumber, c.sectionnumber, c.plannumber, c.planlabel, c.shape
  from CADASTRE c;
As you can see this is about as basic as it gets. There is no join etc. The only thing it does it select a subset of columns. In theory this should be faster than selecting * on CADASTRE. I tried it with and without the /*+FIRST_ROWS*/ hint.
I then described the feature class CADASTRE using sde as follows:
sdelayer -o describe_long -l CADASTRE,SHAPE -i sde:oracle11g:xxx -u GIS -p xxx   (xxx is dumy)
From that I worked out the shape data type, the SRID and the feature types. I then registered CADASTRE_TEST with sde as follows:
sdelayer -o register -l CADASTRE_TEST,SHAPE -e nac+ -t ST_GEOMETRY -C OBJECTID,USER -R 7 -i sde:oracle11g:xxx -u GIS -p xxx
The spatial view is then visible, selectable, identifiable etc in ArcMap/ArcCatalog. However, it is very slow. It is almost as if the spatial view is not using the spatial index from the feature class?
Any ideas? Thank you in advance.
ScottSugden
Same result.
I recreated the view to make sure it was not using any hints. I then ran the following query on both CADASTRE and CADASTRE_TEST:
Select *
From cadastre_test c
Where sde.st_envintersects (c.Shape, 143, -31.9, 144.5, -31.5) = 1;
Returning the first 500 rows over a WAN the CADASTRE table took 1.3 seconds and the CADASTRE_TEST view took 1.2 seconds.
So it would appear that there is no Oracle optimiser issue?
ScottSugden
Ok, the plot thickens. It appears to be an issue with registering the spatial view. I have been registering the spatial view from an Oracle view as follows:
sdelayer -o register -l CADASTRE_TEST,SHAPE -e nac+ -t ST_GEOMETRY -C OBJECTID,USER -R 7 -i sde:oracle11g:xxx -u xxx -p xxx
If I use sdetable to create a view as follows the performance of the spatial view is just fine:
sdetable -o create_view -T cadastre_test1 -t cadastre -c objectid,cadid,lotnumber,sectionnumber,plannumber,planlabel,shape -i sde:oracle11g:xxx -u xxx -p xxx
I have looked through the various SDE tables and found the following differences:
Table COLUMN_REGISTRY (Column OBJECT_ID different)
CADASTRE_TEST1 SDE SHAPE 8 32772 17
CADASTRE_TEST SDE SHAPE 8 32772 0
Table LAYERS (Columns EFLAGS, GSIZE1, BASELAYERID different)
17 SDE CADASTRE_TEST1 SHAPE 608436369 0 0.029 0 0 140.9995956528 -37.4407374802425 159.084596196734 -28.1570205549076 1353439530 DEFAULTS 1 6 7 0 0
16 SDE CADASTRE_TEST SHAPE 1682178193 0 0 0 0 140.9995956528 -37.4407374802425 159.084596196734 -28.1570205549076 1353210279 DEFAULTS 1 6 0 0 0
Table ST_GEOMETRY_COLUMNS (No entry for CADASTRE_TEST1)
SDE CADASTRE_TEST SHAPE ST_GEOMETRY
Table TABLE_REGISTRY (Columns OBJECT_FLAGS, REGISTRATION_DATE (expected), MINIUM_ID different)
22 CADASTRE_TEST1 SDE OBJECTID 131207 1353439389 DEFAULTS 1
21 CADASTRE_TEST SDE OBJECTID 16517 1353210142 DEFAULTS
Obviously the two methods of registration produce different results.
Is there something wrong with my sdelayer -o register?
Is this by design?
Is this a bug?
ScottSugden
More info. I just did a sdelayer -o describe_long on both CADASTRE_TEST and CADASTRE_TEST1 and the only difference is in the Spatial Index.
For CADASTRE_TEST - Spatial Index: SPIDX_AUTOMATIC, exist: No, array form: 0,0,0
For CADASTRE_TEST1 - Spatial Index: SPIDX_GRID, GRID0=0.029, FULL, exist: Yes, array form: 0.029,0,0
I have some complex spatial views to create and would much prefer to use the 'sdelayer -o register' method. How can I use 'sdelayer -o register' and get the view to use the spatial index?
VinceAngelo
Esri Esteemed Contributor
Please contact Tech Support.
- V
ScottSugden
Many thanks for you help.
ScottSugden
For those of you interested the following sde command creates a spatial view with good performance:
sdetable -o create_view -T cadastre_test -t cadastre -c objectid,cadid,lotnumber,sectionnumber,plannumber,planlabel,shape -i sde:oracle11g:xxx -u xxx -p xxx
It is not as nice as 'sdelayer -o register' as that provides more flexibility with complex views, but it is an option.
VinceAngelo
This goes against "best practice" guidelines.
The 'sdetable -o create_view' command should only be used with SDEBINARY or
SDELOB storage layers, where SQL views are not possible.  The preferred mechanism
for ST_GEOMETRY or native geometry types is to generate the view with SQL and use
'sdelayer -o register' (or the geodatabase toolbox equivalent).
I haven't seen the issue you describe, but I'll try to reproduce it.
- V
