Spatial View enable with Sync
1720
03-06-2024 11:52 AM
vijaybadugu
Have a requirement to publish a query feature layer (view ) with sync enabled  and have offline capability . this layer can be used in field maps app for READ_ONLY purpose.
is it possible to publish a view with sync enabled service ?
MarlonAmaya
Hi @vijaybadugu ,
Requirements vary depending on what you need to do. But one of the requirements is that the all data must be registered with geodatabase.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/prepare-feature-layer-data-...
Marlon
vijaybadugu
I tried to enable archiving/GlobalID fields to work as sync enabled feature service, did not work and final goal is to add that view layer to the field maps just read only purpose. I registered data with geodatabase.
vijaybadugu
Any solution/work around for this ?
