Spatial References
1196
11-15-2012 04:55 AM
AndyBurnell
Hello. I am working with a file gdb that contains about 107 feature class and 12 feature datasets. The problem that I am having is that from time to time if I try to move a feature class from one dataset to another I receive an error saying spatial refs do not match. I have checked and everything is identical. Is there anything I can do to make things right?
I am using 10.1 sp1 desktop advanced on XP pro sp3, but have also run into this using 9.31.
LanceShipman
You can fix the problem by loading the feature class into the feature dataset that you had a failure in copy/paste. Feature Class to Feature Class will correct differences in spatial reference. Copy/Paste (drag/drop) will not correct for differences in spatial reference.
