Sometimes "Invalid parameter value passed to function" when using ChangePrivileges
7975
8
08-10-2010 06:52 AM
RPW
I am automatically setting permissions on Feature Classes in ArcSDE using Python. The problem is that this only works if I run the script on the workstation; if I run it directly on the server where ArcSDE is installed, I get the following error message:
Failed to execute (ChangePrivileges).
The command looks the same using both ways (print gp.GetMessages()):
Executing: ChangePrivileges <SDE_CONN_FILE>/<ADMIN_USER>.<FC> <USER> GRANT AS_IS <SDE_CONN_FILE>/<ADMIN_USER>.<FC>
The strange thing is that the FC is appended again in the end, although the syntax looks like this:
ChangePrivileges_management (in_dataset, user, view, edit)
But I don't think this is the reason, since it works on the workstation.
Here is the code:
# Process only FC where admin_user has access -> wildcard
  wildcard = "%s.*" % admin_user
  fcs = gp.ListFeatureClasses(wildcard)
  fcs.reset()
  fc = fcs.next()
  while fc:
   fc = conn_sde + "/" + fc
   print "Setting read permission on FC %s" % fc
   try:
    # Process: Change Privileges...
    gp.ChangePrivileges_management(fc, read_user, "GRANT", "AS_IS")
   except:
    # If an error occurred while running a tool print the messages
    return 1
   fc = fcs.next()
ArcGIS version: 9.2, SP6
ArcSDE version: ArcSDE for Oracle9i 9.2 Service Pack 3
Does anyone know why the same command would run on a workstation but not on the server?
Thanks a lot,
Ralph
RandyKreuziger
You write that ArcSDE on the server is also running 9.2 but is there a chance it has a newer or older ArcGIS Desktop than your workstation?  Didn't the parameter list of the ChangePrivileges command change between versions?
VinceAngelo
Esri Esteemed Contributor
If you enable tracing (with SDETRACELOC/SDETRACEMODE variables), you'll know what's wrong for sure,
but 92sp3 != 92sp6, so your PATH order in resolving SDE.DLL could be the deciding factor.
- V
RPW
It is the same ArcGIS version (9.2) on both the workstation and the server, and I think also the same SP; but I will check this.
Ralph
RPW
I will try to enable the tracing. I don't understand the thing with the PATH order and the SDE.DLL; are these critical for the ChangePrivileges cmd or for the tracing?
Ralph
VinceAngelo
If you have ArcSDE 9.2sp3 and ArcGIS 9.2sp6 on the same host, they will both have
a DLL named "SDE.DLL", but one will be SP3 and one will be SP6.  The LoadLibraryEx()
function is used to load dynamic libraries, and it searches directories in the order
specified by the PATH variable.  If your SP3 bin directory is before the SP6 directory,
then the 92sp6 ArcGIS will use the outdated DLL, making it unreliable.
There are a multitude of reasons to install ArcSDE 9.2 SP6 and the post-SP6 patches;
eliminating search order conflicts as a possible problem is one of the less pressing ones,
but if it works, then the other issues won't give you trouble either.
- V
RPW
Thanks for the detailed explanation. I will be able to have a look at this next week. And yes, probably it would not harm to install some SPs and patches 🙂
Cheers,
Ralph
RussellBrennan
Ralph,
One other thing to double check is to ensure that the SDE connection file that you are using on the server is using exactly the same connection properties as the one you are using on the client machine.
RPW
Russell,
I am using exactly the same SDE connection file.
Ralph
