service
2051
10-04-2016 10:14 PM
jayasudha
arcsde service is not started with error, "This instance's service name test not found in system services file"
working with oracle 11gR2 and arcsde 10.1
(1) i have added service info in services file both in sdehome and windows
(2) create service is successful.
(3) start service is failed.
DerekLaw
Esri Esteemed Contributor
Hi Jaya,
It's been awhile since I worked with the ArcSDE service, this doc might help: Problem: ArcSDE server fails to start up
Suggest you contact Esri Tech Support, they are the best folks to help investigate your issue.
Hope this helps,
DerekLaw
Hi Jaya,
Please review this help topic:
Troubleshooting an ArcSDE service - ArcGIS Help 10.1
Hope this helps,
jayasudha
The event viewer (windowslogs->system) in windows 7 machine says following.
The ArcSde Service(esri_sde) service failed to start due to the following error:
The system cannot find the file specified.
DerekLaw
Hi Jaya,
Hope this helps,
jayasudha
Thanks for suggestions
