Select Feautures tool is grayed out
2842
03-02-2013 03:18 PM
ShannonMann
I am needing to use the Select Features tool to select a point I need in my project.
I am using ArcMap 10.0, and have been using this tool throughout my project, but for some reason it is grayed out and won't allow me to click/select it.
What do I need to do??
MelanieSummers
Hi Shannon,
Are any of your layers selectable? You can toggle this on an off by viewing your layers by Selection in the Table of Contents, make sure at least one layer is selectable (blue) like in the attached image.[ATTACH=CONFIG]22343[/ATTACH]
Best,
Melanie S.
BryceGardner1
Hello Shannon,
You may try closing and restarting Arc. This usually works for me when I encounter an odd situation. I hope this helps.
Regards,
Bryce
