sdemon commands in Arcgis Desktop 10
1082
12-12-2011 08:24 AM
AshakaThakore
What should i install to have sdemon, sdelayer,sdetable etc commands in my machine. I am using arcgis desktop 10...
Should i install the "Arcsde for Microsoft SQL Server 2008" just to have sde - commands???
I am using windows 7 64 bit
thanks a lot
CarolynDefoore
You don't need to install anything.  All you need  are the SDE binaries.  You can copy them locally from the machine where you have ArcSDE installed (you will need to configure your environment variables on your local machine after you copy the bin folder).  Alternately, you can always just run the commands directly from the location where you have SDE installed.
VinceAngelo
Esri Esteemed Contributor
While it's true that you don't need a full install of ArcSDE to run ArcSDE commands, I would
strongly encourage you to go through the install (and cancel the post-install), so that your
release is populated in the system registry.  This will permit you to apply patches and service
packs to keep your command-line tools in sync with your database.
Going "registry commando" is usually only an advanced technique since, while it lets you run
multiple versions of ArcSDE, it also deprives you of Start Menu access to documentation and
GUI tools for ArcSDE management.
- V
