sdedc_SQLServer.log
1820
08-18-2010 08:19 AM
KobeHarkins
So if all your users have direct connections to geodatabases, is the giomgr_esri_(gdb).log and sde_esri_(gdb).log useful anymore? Should I be reviewing the sdedc_(dbms).log instead? Also, when I go into my sdedc_SQLServer.log file it has the following message:
SDE Server Release 9.2.0 is not compatible with the current Release 9.3.0.
I am not sure what this means. Any ideas?
Thank you,
Kobe
VinceAngelo
Esri Esteemed Contributor
Direct Connect is going to log to the SDEHOME from which the connection is made;
if you decentralize your connections, you also decentralize your connection logs.
That message may just be from a 'sdesetup -o upgrade', which uses Direct Connect
locally on the server.
- V
KobeHarkins
Thank you for your reply Vince. Once we finally move SDE to 10, we will see if the message disappears. Thanks again.
Kobe
