SDE.default not compressed
2467
01-20-2013 12:56 AM
FaisalBukhari
I have only one version name as  "SDE.default"  ,concurrent users  are editing on  SDE.default version .
when i  run compress statement  its give me message  compress successfully .
but when i run the command "sdeversion describe" the state id is not reducing its continous increasing.
Thanks in Advance
JakeSkinner
Esri Esteemed Contributor
Check to make sure no users are connected to the database when you execute the compress.  Also, if you have any replicas be sure they are synched before the compress.
http://support.esri.com/en/knowledgebase/techarticles/detail/29160
FaisalBukhari
Dear J
Thanks for reply sure no user connected and no  replicas  are exists
Faisal
