SDE Connection 10.1
1255
08-26-2013 03:42 PM
Arturo_FranciscoAcosta_Bazán
There is an  Geodatabase mount over Oracle 11g  that needs to be accesed by clients outside the LAN.
Generating an SDE service over a public IP is the only option available for this clients to conect to the DataBase.
These clients do not have a VPN to log in.
It should continue to use SDE Connections ??
VinceAngelo
Esri Esteemed Contributor
Best practice would be to always have a VPN link -- At a minimum, you could engineer an
SSH session on a non-standard port through a firewall via a proxy.  Direct Internet access
is really too scary to contemplate.
- V
