SDE 10 upgrade 'ARITHABORT'
2637
07-29-2011 04:28 AM
anthonychapa
Error(Check Datasets): Underlying DBMS error [Microsoft SQL Server Native Client 10.0: CREATE XML INDEX failed because the following SET options have incorrect settings: 'ARITHABORT'. Verify that SET options are correct for use with indexed views and/or indexes on computed columns and/or filtered indexes and/or query notifications and/or XML data type methods and/or spatial index operations.]
FYI
Caused by database compatabilty level.
CattyannCampbell
How did you fix this? I'm getting the same problem after upgrading SDE and trying to upgrade the geodatabase to the 10. What can I do about this?
YosephMekasha
I encountered the same problem and could not figure it out... if you have the solution please
YosephMekasha
I found the solution it is just setting the comparability level of the current data. In my case I was migrating from SQL server 2000 to 2005. Thus used the following to fix the compatibility problem
exec sp_dbcmptlevel sde,90
