Schema Wizard Tool in ArcCatalog 10
4417
11-19-2010 04:26 PM
RicardoSanabria
Hi everybody,
Where is Schema Wizard Tool in ArcCatalog 10? I haven't found this tool.
Ricardo
DerekLaw
Esri Esteemed Contributor
Hi Ricardo,
FYI: the Schema Wizard tool is now a separate install from core ArcGIS. You can access it from your media disc or download from the Esri Customer Care site. Please see this blog post from the Geodatabase development team on the status of CASE tool support in ArcGIS:
Using CASE tools in ArcGIS 10
Hope this helps,
JonHall
Hurray! Thanks for the info, Derek, I thought this tool had been deprecated.
-Jon
RicardoSanabria
Thank you, I installed Case Tools and it works!
Regards,
Ricardo
DerekLaw
Hi qadir3435,
I can not download Schema wizard even Esri Customer Care site.
Did you contact someone at the Esri Customer Care site for assistance? Did you email them and provide your customer info? Please do as I am sure someone will follow up.
Hope this helps,
ThomasSlingsby
After installing CASE Tools I get the following error whenever I open ArcCatalog:
DDE Server Windows: ArcCatalog.exe - No Disk
There is no disk in the drive.
It doesn't actually affect anything and I can cancel the error but it's very annoying. I have uninstalled CASE tools and the error persists. I will try and reinstall SP4 and see if it helps
