Schedule a Spatial ETL Tool
2616
09-01-2011 06:02 AM
PaulSchneider
I have an ETL tool that converts a SDE feature dataset into a Microstation V8 file.  I would like it to run automatically on a weekly basis.  What is the easiest way to go about this?
Thanks!
BruceHarold
Esri Frequent Contributor
Hi Paul
Run your ETL tool and from the results window right click the result and copy it as a Python snippet.
Then create a standalone Python script that imports arcpy and imports the toolbox, before executing the snippet, like:
import arcpy
arcpy.ImportToolBox(r'C:\Temp\NEARBug.gdb\NEARBug')
arcpy.SpatialETLTool("'C:/Work/Product Management/Loqate/Loqate.gdb'","geodatabase")
Then follow the directions here to make the script a scheduled task:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//002100000038000000.htm
Regards
