Restore an ArcSDE database backup to a database with a different name?
4378
03-05-2013 08:23 AM
deleted-user-1T_bOHag6M8d
I am using ArcSDE 10.1 and PostgreSQL 9.1/PostGIS 2.0. I have backups of a production database that I'd like to use for a development database. The name of the development database appends "_dev" to the database name to avoid confusion. However, when I restore the production backup to the development database, I receive the following error on connection:
2013-03-05 08:07:28 PST ERROR:  cross-database references are not implemented: "cvag.sde.sde_object_ids" at character 21
2013-03-05 08:07:28 PST QUERY:  SELECT base_id FROM cvag.sde.sde_object_ids WHERE id_type = i_id_type FOR UPDATE
2013-03-05 08:07:28 PST CONTEXT:  PL/pgSQL function "sde_get_primary_oid" line 15 at FOR over SELECT rows
2013-03-05 08:07:28 PST STATEMENT:  SELECT cvag_dev.sde.SDE_get_primary_oid ($1,$2)
Which leads me to believe that one or more functions in the sde schema is defined with database names as a reference and restoring to a database with a different name doesn't work.
I have also tried creating the enterprise geodatabase first and then restoring a backup of the production database that excludes the 'sde' schema. The connection works, but now my 800+ feature classes are not registered with the geodatabase.
Are there any best practices published for working with production and development databases that might help me here?
Thanks.
MandarPurohit
As you've already mentioned, the database name is indeed referenced in a PostgreSQL geodatabase repository. You will need to restore the database with the same name. This issue also applies to a SQL Server geodatabase is described here : FAQ:  Can I restore an ArcSDE geodatabase with a different database name in SQL Server?
