Removing ArcSDE 9.3.1 and Installing ArcSDE 10 on SQL Server 2005 - Procedure?
2206
10-18-2011 12:29 AM
Kevin_RogersBwire
What is the correct procedure for removing ArcSDE 9.3.1 and Installing ArcSDE 10 on SQL Server 2005 Enterprise Geodatabase
VinceAngelo
Esri Esteemed Contributor
Are you sure you want to "remove" 9.3.1?  Or do you want to *upgrade* to ArcGIS 10.0?
Either way, the details are in the documentation (just use the upper left search field with
"Uninstall ArcSDE" or  "Upgrade ArcSDE" or "Install ArcSDE").  Please do make sure you're
using a supported SQL-Server 2005 build (SP2 or SP3) before you start the upgrade process.
- V
