Remove duplicate lines
2130
07-16-2014 04:38 AM
BenLeslie1
(I've removed duplicate points by doing a dissolve on XY coords.)
Now I need to remove duplicate lines (by duplicate I mean identical geometry - they may have different attributes but I don't care which one I keep).  I've used the Intersect tool to identify the duplicates but I don't know how to merge each duplicate into single records.  I have 7000 duplicates so manual merging isn't a realistic option.
I'm on standard licence.
BenLeslie1
Unfortunately erase duplicates isn't one of the free functions in ET Geowizards.
I'm attempting to iterate through my dataset, selecting identical and deleting using model builder.  It's not very intuative - had some strange results.... currently running attempt 3..... fingers crossed.
JohannesBierer
Don't know if I really understand. But the normal erase is a free function in ET Geowizard, I do use it often ...
Do you have the identical lines in one fc or in two?
BenLeslie1
Just one dataset (actually it was originally about 120 but I've merged them all into one - that's the goal, one dataset with duplicate geometries removed)
JohannesBierer
Maybe you could use the python script there:
How to delete duplicates...
