Registering ArcFM geometric network data with ArcSDE
773
11-03-2010 02:16 AM
LavanyaS
Hi ppl,
          Am workin on ArcSDE with DB2 and got stuck with registering the ArcFM sample data(miner&miner) to ArcSDE.The sample data of ArcFM has this electric dataset,water dataset,gas dataset along with few others.I could register all these from ArcCatalog using the regular copy&paste method which is used to register your geometric networks with SDE.Problem is we are not able to use ArcFM properties manager and unable to set any model names.
     i'm litle sceptical if just the copy&paste method to register the GeometricNetwork data would be sufficient or if thr are any further steps to be followed.If so can you kindly lemme know what are the required steps to be performed to register the FM data having Geometric Networks to SDE?
Lavanya
