Reconcile crash
1141
08-15-2013 06:33 AM
ChiragDanech
I am running ArcGIS 10 with Service Pack 5 and Geodatabase reside in SQL Server 2008 R2 with ArcSDE 10. I have loaded almost 14 million point records into child version of sde.DEFAULT. Now when I tries to reconcile and post using ArcCatalog/ArcMap/Python Script it's running for 3 to 4 hour and crashing. I am not getting any error message.
Anybody knows any work around or how to fix this issue?
Thanks in advance
WilliamCraft
How much memory do you have on the machine performing the reconcile?  Is the RAM and CPU indicator in Task Manager maxed out when running the reconcile?  Check the Windows Event Viewer for crash reports to see if you may be able to identify a bit more information; also ArcMap does generate crash dump files in the user temp directory so that may be something to review. Another option might be a to reduce the number of edits in the child version and reconcile/post multiple times.
