Rebuild Indexes Error - Object has no schema locks
4162
04-05-2013 07:04 AM
LauraSilsbee1
I received the following error when trying to rebuild indexes on an 10.1 enterprise geodatabase:
Could not rebuild indexes for dataset egis93.SDEDATA.WTR_INVENTORY/egis93.SDEDATA.WR_WaterBodies.[Object has no schema locks.]
Failed to execute (RebuildIndexes)
Not sure where to look to correct this - suggestions welcome.
MichaelDesroches
I just ran into this... and am wondering if it's because the dataset is actually empty. Did you ever figure this out?
ChelseaRozek
MVP Regular Contributor
I don't think this will help you in your situation, but in case anyone else is getting this error, here's what helped me. I was trying to run a spatial join on a hosted feature layer in ArcGIS Online with a local feature class in Pro. Got this error: ERROR 160244: Object has no schema locks.
I reprojected the local feature class into web mercator like the hosted feature layer and then it worked fine for me.
