Raster Calculator - applying the following formulae for MODIS NDVI
1939
05-24-2010 01:15 AM
JonathanMcCloskey
I am trying use MODIS Surface Reflectance Bands 1 and 2 rasters to calculate my own daily NDVI products using the following formula
NDVI = (Raster 1 - Ratser 2)/(Raster 1 + Raster 2);
The pixel values should be in decimals but when I run through Raster Calculator I get whole numbers and everything is zero.  Does anyone know off a way to get the results in decimals?
Many thanks
Jon
DanPatterson_Retired
did you copy and paste the equation from the raster calculator?  the first subtraction says Ratser 2
also, did you type in the equation or did you select rasters and the operands to form the expression?
JonathanMcCloskey
Dan,
Nope the equation was just typed in and is short names for the actual layers, everything i sselected from the layers.  The formulae works but I get the values in whole numbers ie -1, 0, 1 (this is the range of NDVI values) however I need to know the decimal figures to 2 decimals points. ie 0.23, 0.47.......... etc.
Raster calculator seems to automatically round the decimals to the nearest whole number which is casuing me the problem.
Many thanks
Jon
JonathanMcCloskey
sorted, just have to add float to the start of the equation
thanks
Khairul_AzwanMohamad
