"Function requires a state to be set for stream versioning geodatabase" error
1530
06-16-2025 03:49 PM
Labels (3)
AliciaMcMurchie1
I'm getting a "Function requires a state to be set for stream versioning geodatabase" error while trying to edit a traditional versioned feature class in a dataset of an Enterprise Geodatabase. Has anyone seen this before? I'm confused as to what could be going wrong.
DanPatterson
MVP Esteemed Contributor
really old, but the only one with that message
Solved: RuntimeError: Function requires a state to be set ... - Esri Community
... sort of retired...
AliciaMcMurchie1
Thank you - I took a look at this earlier, but I wasn't able to figure out a solution based on what the poster describes happening. I'm working entirely in ArcGIS Pro, not using a script, and editing in ArcGIS Pro has changed significantly. I've started a support case with Esri.
LisaHuggins1
Hello, Did you resolve this issue?  We got the same message this morning.
AliciaMcMurchie1
The error resolved, but I'm unsure why, unfortunately. I haven't been able to replicate it.
