Quick Export manually works, but Quick Export geocoding does not?
1172
03-16-2012 09:44 AM
WingKuang
I've been having issues using Quick export through python coding, but it works through arcmap. What I did was essentially copy the same parameters from the output dialog and use them, but PostGis doesn't seem to be getting the data, only the name of the database I passed in.
BruceHarold
Esri Frequent Contributor
Hello Wing
In your Python script, make sure you are checking out the extension before calling the Quick Export tool:
arcpy.CheckOutExtension("DataInteroperability")
Regards
