question with 'add x/y data'
835
07-10-2012 01:02 PM
TedBierman
hi all,
pretty new to this...
have a quick question.
My project is in StatePlane Utah NAD83(ft). I'm trying to add lat and longs to the addresses so i can insert the points into my project and run a 'route' type analysis on them.
I have two questions:
1. I'm having a heck of a time with the external table (.dbf/.csv) file that i have my addresses/lat/long on to 'import' correctly into my above mentioned projection?
    I've tried just simply bringing it via Tools-->adding xy data, i've tried the same and them saving out in current coorinate system and then opening that file, I've tried 're-projecting' it in ArcToolBox..... just can't figure it out?!?!!?! any thoughts???!? guessing its really simple and im just missing something easy! 🙂
2. Is there anyway to run a 'route' type operation with the points i'm trying to make if I have all the street data?
Thanks so much and FYI using ArcMap 9.1.
Please respond to this thread or directly to [email protected]!
Cheers!
