Projection Problem
6354
11
12-03-2015 01:53 PM
AlexanderPugliese
I just uploaded a bunch of points using the display XY data in the following format:
Lat: 38.655666 Long: -122.793479
No matter what projection I originally set everything to it always projects into the ocean.  All the points seem to be accurate and when I search the lat/long in google earth they are accurate so I'm a bit lost atm.
I've set the data frame coordinate system to the same system I am using on my layer.  I've tried everything from adding the data in a current ArcMap document to a brand new one and I keep getting the same results.
Does anyone have any suggestions?
Thanks!
~alex
RobertBorchert
Honored Contributor
Try this.  start a blank MXD session.  Add only the XY table and create the event from the XY.  Then export that to a database that's in the projection you want.
When using decimal degree data it seems to default to the proper projection for displaying the raw data.
I just did it with the xy you posted and it comes up as Alexander Valley School.
RobertBorchert
Honored Contributor
Or more specifically it appears to be on the roof of the school
