Projecting a Fantasy Planet!
1389
02-17-2012 06:59 PM
BradNace
Ok,
So as an experiment I drew out a �??world map�?� using the world mercator style for a fantasy planet. Now assuming this fantasy planet matches the earth in proportion and scale, how would I go about getting the map correctly projected into ArcGIS? The idea is to make a series of overlays, mostly showing regions of the planet, etc, and serve the data up on GeoServer. Suggestions? Is it even possible?
Known Information:
TIF file
Size: 52426 pixels x 26214 pixels
Thanks!
-Avo
AnthonyTimpson2
Just georeference your TIFF over a world map in the same projection and define the tiff projection after rectifying.
BradNace
:confused: Ok. I was making that was too complex and difficult. Thanks for the help, that worked!
