Problems exporting large SDE to XML workspace document
3122
06-25-2012 07:26 AM
TylerBoyle
I'm trying to export a large SDE to XML so that is can be sent to a client. First I tried export in xml format but the file was too big and the export failed before it could finish. So I'm exporting in the compressed Z file format. The exports run successfully and my file size is about 10gb. Then I'm importing into another blank SDE to make sure it worked properly. The import process runs successfully but, after scanning through some of the feature classes, many of them are missing data. All schema comes across though. Does anyone know what could be causing this? Is the file size still too large for Z files?
Any help appreciated
Tyler
