Problem using st_linefromtext on "large" linestrings in 10.1
850
03-06-2013 07:05 PM
idolevi
Environment: Arc SDE 10.1 , Oracle 11g r2, Arcgis Server 10.1
I have table with linestring clob column, the linestring are larger than 4000 bytes.
When I try to do a select using sde.st_linefromtext on the clob column, i get:
System.Data.OracleClient.OracleException: ORA-20004: Error generating shape from text: Invalid text used to construct geometry (-1).
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 12
ORA-06512: at "SDE.ST_LINEFROMTEXT", line 58
But it works fine when I run the same select on the same column in different environment: Arc SDE 10 , Oracle 10, Arcgis Server 10
Does Arcgis 10.1 has size limitation?
Ido
VinceAngelo
Esri Esteemed Contributor
This is certainly something to take to Tech Support.  Be sure you provide them with the exact
service pack (and patch, if present) [ArcGIS] or patchset [Oracle] installed on your servers and
clients (for both Oracle and ArcGIS).  If you're not using 10.1 SP1, you should also test it.
- V
