problem on Raster to Netcdf
8859
12
07-09-2012 08:58 AM
JianSun1
I am trying to convert a raster file to netcdf, but i get a nearly empty netcdf file (about 4k) every time. I basically follow the instruction, really have no idea what i am missing. I appreciate any suggestions.
Best,
Jian
ConnyTschritter
I just had the same issue and thought I should post my solution, just in case anyone else encounters the same problem. I was using ArcGIS 10.2.2, and every time I tried to convert a raster file to NetCDF, it resulted in a 4kb NetCDF file that didn't come with any parameters and couldn't be plotted. Thankfully, I thought of trying the same tool at a colleagues computer that had ArcGIS 10.3 installed. And voila, it worked. So just in case you also have this problem, try to make a raster NetSDF using ArcGIS 10.3 instead.
yurigorokhovich1
Thanks! Great advice! It works!
yurigorokhovich1
Just follow advice from Conny Tschritter, it works! I downloaded 10.5 and all issues are solved (at least for now!)
