Polygon Straddling 180th Meridian
504
02-19-2013 02:02 PM
HannahOwens
So I'm still pretty new at ArcGIS10, and I have made a polygon in the Pacific Ocean the straddles the 180th meridian. I created it in a project projected so that the 180th meridian is at the extreme right and left of the projection. Can anyone suggest how I might re-project these polygons so that the 180th meridian is in the middle of the projection with the Prime Meridian on the extreme right and left?  Additionally, how can I edit the polygon so that I can join the two polygons from either side of 180 degrees to make one single shape?
Thank you so much in advance.
