Permissions a particular user has for a particular layer ??
1242
10-03-2011 07:46 AM
HalilSiddique
Hi all,
What i want to do is to identify all the permissions a particular user has for a particular layer
what sde command do i need to run to get this info? or do I have to use SQL plus (if so what would the script look like?)
Cheers
Halil
VinceAngelo
Esri Esteemed Contributor
'sdelayer' will report access to the connected user, but nothing in the ArcSDE API tracks
*other* users -- You'd need to traverse the RDBMS rulebase for this information (and
need administrative access to do so).
- V
HalilSiddique
Hi Vince,
i know about "sdelayer", what I was hoping for was UserA has read/ write / edit metadata  on layer1 and then compare that layer with layer2 in essence.
Halil
AJR
you may want to take a look at http://arcscripts.esri.com/details.asp?dbid=16024
