Parcels Geocoding
1369
02-07-2014 04:36 PM
GuyKouwoaye
I have difficulty geocoding parcel numbers. I used US-Single house locator but it returned 0 match. What can I do?
RobertBorchert
Honored Contributor
Don't geocode the parcel numbers.
Use the Feature to Point function and check to box to do inside.  This will create a centroid for all your parcels in one operation and include all data from the parcel polygons.
You can geocode but it can be a pain.
If you don't have parcel polygons and are trying to geocode using a geocoding service that should not work as the service would have to contain all the parcel numbers as part of its locational data.  And I have not seen that before.
JeffRogers
I recommend you try building the locator using the "General - Single Field" locator style.
This style is more appropriate for Parcel IDs.
