Parcel Editing - using breakpoints
993
08-24-2011 04:52 PM
AlanaEaston
I am trying to cut a small section out of a parcel using construct from parent.
There are no existing verticies/line points so I am creating two breakpoints to snap to. However when I try to add the bearing and distance measurements they revert back to all 0-0-0 after using one of the breakpoints as a starting point. I have used breakpoints to adjust a parcel before but starting the cut from an existing verticie/point. Can you help.
