Parallel lines with a specific distance between
904
10-19-2012 11:54 PM
PatrickDornberger
Hi there.
I should create several parallel lines with the same specific distance (30 meters) between. How can I do that?
Thanks a lot!
Patrick
T__WayneWhitley
Honored Contributor
Basically, in an Edit session, select:
- feature to copy
- 'copy parallel' from the Editor menu
- target fc...
(And of course, enter your distance, other options like side, etc.)
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001t00000033000000.htm
T__WayneWhitley
Honored Contributor
- feature to copy
- target fc...
