Overlap Image
952
01-25-2011 05:47 PM
BeakHyungi
I am trying to overlap aerial images to Tin data.
Please, let me know how to overlap images to Tin data.
Also, is the image overlaped displayed in 3D like Tin data?
Thank you.
RobertBerger
Greetings,
If you're trying to visualize your tin and image in 3d, then you probably want to use ArcScene or ArcGlobe (depending on what you are trying to accomplish). Try to load your tin as the elevation data and then drape the image over it.
Is that what you're looking for?
Robert
DylanIrion
In ArcScene, open the layer properties of your satellite imagery and select the "base heights" tab. Tick the radio button that corresponds to "obtain heights for layer from surface" and browse to your tin.
