Oracle Error PLS-00707 trying to compile a store procedure using a call to sde.st_intersects.
13264
09-20-2015 10:07 PM
marceloctorres
When I try to execute the following PL-SQL code I have right results:
But when I try to compile a store-procedure using a similar code I get a compilation error:
What I have to do to fix this error?
Marcelo...
Marcelo César Torres
GuillermoMarinez1
Hi Marcelo
you must use this reference of intersect operation in PLSQL code: "sde.st_relation_operators.st_intersects_f"
this is because PL/SQL requieres referencing the underlying functions by fully qualifying their appropiate package and function name.
look this link:
36094 - Leverage st_geometry operators in Oracle's PL/SQL
GuillermoMarinez1
Hi Marcelo
look this link:
MarceloMarques
To BottomTo Bottom
In this Document
Symptoms
Cause
Solution
APPLIES TO:
Oracle SQL Developer - Version 3.2 and later
Information in this document applies to any platform.
SYMPTOMS
sql developer version: 3.2.20.09
Database version: 11.2.0.3
Attempting to compile Function/Prucedure/Package in SQL Developer throws the following error:
PLS-00707: unsupported construct or internal error [2603]
This issue is not occuring in sqlplus. This issue occurs only for the 11g/11gr2 Database on SQL Developer.
CAUSE
It seems to be caused by the  parameter PL/SCOPE variable when it uses the value "IDENTIFIERS:ALL".
SQL Developer during connection establishing changes the session parameter PLSCOPE_SETTINGS from IDENTIFIERS:NONE (default) to IDENTIFIERS:ALL.
Same error was received in SQL PLUS when issuing an "alter session set PLSCOPE_SETTINGS=IDENTIFIERS:ALL".
More about PL/Scope can be found here:
http://docs.oracle.com/cd/B28359_01/appdev.111/b28424/adfns_plscope.htm
http://docs.oracle.com/cd/B28359_01/server.111/b28320/initparams178.htm
SOLUTION
1. Go to Preferences in SQL Developer.
2. Then go to Tools -> Preferences -> Database -> PL/SQL Compiler
3. Change the "PLScope identifiers" from All to None
4. Restart the SQL Developer.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
