Offset Process
746
05-10-2012 01:04 AM
EmraSERT
Dear All, I have a feature class and my feature has 88 line records, this records has line number field (1-88), I want to create a offset according to line number, I will want to go 10 meters offset inter lines according to line number, according to this situation first line number is offset position is 0 then second line offset amount 10 m, third line offset amount 20 m .... and last line offset amount 880 m. How to I doing for this situation. (Note: I was trying Geotools, Schema, Buffer, Editing-Offset)? Please help for this situation.
JuanLuera
Hola Emra,
In doing some research on this for you, I was able to locate the following tool, which might assist in your scenario. Let us know if this will work for you or not, and we can always look into some other possible options. Gracias, Emra!
About making a parallel copy of a line
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00q8000000s3000000
