OD Cost Matrix and Origin IDs
1387
07-08-2014 01:26 PM
MichaelCatsos
I have created an Origin-Destination cost matrix showing the distance in feet between several thousand home addresses (origins) and about 24 rental vehicles (destinations) at various points throughout the city. Each address point that was input into the OD matrix analysis also originally contained information on the number of times the resident at each address had reserved a particular vehicle.
My goal is to create a table that will show, for all home addresses, the distance from that address to each of the 24 rental cars and the number of times the resident reserved each of the 24 cars. I could then say, for example, "40% of reservations made by residents of Neighborhood A are for cars within 1/2 mile" or "Residents who reserved car X lived an average of 2000 feet away".
Here is the problem. In conducting the OD matrix analysis, it seems that all the unique identifiers of the data that I input have been obliterated. It would appear that there is no way to associate the distances between origins and destinations back to the other attributes associated with the home address points except for some sort of spatial join. Yet, between the inaccuracies introduced by geocoding thousands of addresses and the fact that many home locations are apartments with multiple residents in the same building, it is impossible to distinguish which resident made which trips by using a spatial join.
How have others typically handled the origin-destination problem when origin points overlap and still need to be associated back to other attributes? Any help would be greatly appreciated.
MirceaMaierean
Im in the same dillema. Im trying to match anglers to fishing waters. The problem is that all the attributes from the origin (anglers) and the destination (waters) does not pass over. So there is no way for me to sort them out and only keep the required information i need.
The only solution I have found was to select by attributes all the anglers for each individual water then performe 100 and so network analysis. and then join and sort by angler ID. But that would take way more than the ability to keep original fields or add fields with original data on the Solved lines.
