Non versioned editing and geometric network
1008
10-03-2011 10:44 AM
ZarehDemirdjian
Hello !
Can a non-versioned editing be performed on a geometric network data?? or only versioned editing can be performed on this kind of data?
Thank you in advance,
Zareh
Robert_LeClair
Esri Esteemed Contributor
Zareh,
You cannot edit features classes in a geometric network.  NVE is allowed for simpled data only - points, lines, polygons, annotation, and relationships.  Basically, anything that participates in geodatabase behaviors cannot be edited in NVE.  With that set, if you unregistered your Feature Dataset as Versioned then the data becomes "simple" again and then you can edit the data.
Please see the following URL for details:  http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#//009300001634...
Regards,
Robert LeClair
Esri-Denver
